[postgis-tickets] [PostGIS] #3576: Error in Manual - ST_NumInteriorRings (8.5. Geometry Accessors)
PostGIS trac at osgeo.org
Mon Jun 13 19:31:18 PDT 2016
 Reporter:  ruvyn                    |      Owner:  robe
     Type:  defect                   |     Status:  new
 Priority:  medium                   |  Milestone:  PostGIS 2.3.0
Component:  documentation            |    Version:  trunk
 Keywords:  PostGIS 2.3.0dev Manual  |
 String #226 and #228 in 'reference_accessor.xml.plot' are against each
 other:
 #226 "This will work with POLYGON and return NULL for a MULTIPOLYGON type
 or any other type."
 #228 "This will work with both POLYGON and MULTIPOLYGON types but only
 looks at the first polygon. Return NULL if there is no polygon in the
 geometry."
 Can you tell me which is the correct statement?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3576>
