[postgis-tickets] [PostGIS] #3576: Error in Manual - ST_NumInteriorRings (8.5. Geometry Accessors)
PostGIS trac at osgeo.org
Tue Jun 14 02:50:30 PDT 2016
  Reporter:  ruvyn          |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 2.3.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:  PostGIS 2.3.0dev Manual
Changes (by strk):
 * cc: https://www.transifex.com/postgis/postgis/language/en/ (removed)
Old description:
> String #226 and #228 in 'reference_accessor.xml.plot' are against each
> other:
> #226 "This will work with POLYGON and return NULL for a MULTIPOLYGON type
> or any other type."
> #228 "This will work with both POLYGON and MULTIPOLYGON types but only
> looks at the first polygon. Return NULL if there is no polygon in the
> geometry."
> Can you tell me which is the correct statement?
New description:
 RE https://www.transifex.com/postgis/postgis/language/en/
 other:
 or any other type."
 geometry."
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3576#comment:1>
