[postgis-tickets] r15360 - Fix mistakes and some rewording
bjorn at wololo.org bjorn at wololo.org
Fri Apr 21 12:40:18 PDT 2017
Author: bjornharrtell
Date: 2017-04-21 12:40:18 -0700 (Fri, 21 Apr 2017)
New Revision: 15360
   trunk/regress/README
Modified: trunk/regress/README
--- trunk/regress/README	2017-04-21 17:21:10 UTC (rev 15359)
+++ trunk/regress/README	2017-04-21 19:40:18 UTC (rev 15360)
@@ -79,13 +79,11 @@
 would elicit different responses from JTS vs GEOS compilations.  Since
 JTS is no longer supported, this may not be required anymore.
 Notes about running individual regression tests
-The script regress/run_test.pl can called directly to run individual
+The script run_test.pl can be called directly to run individual
 regression tests. Run it without parameters for info about its usage.
-But it should be noted that tests run in a staged install that require
-running make -C regress/ staged-install to actually use the current
-local build. This is called automatically when using make test.
+Note that tests run in a staged install which is created by running
+make staged-install. This step is a part of the complete make check.
