[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
PostGIS trac at osgeo.org
Sat Apr 22 19:37:02 PDT 2017
 Reporter:  robe     |      Owner:  Björn Harrtell
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Both debbie and winnie are showing this regress error on mvt regress
  mvt .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.6.1_gdal2.1.3w64/test_120_diff)
 --- mvt_expected        2017-04-21 13:42:19 -0400
 /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.6.1_gdal2.1.3w64/test_120_out
 2017-04-21 15:56:31 -0400
 @@ -25,8 +25,8 @@
  TA6|GisKBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgIwASiAIHgC
 TA7|Gk4KBHRlc3QSDBICAAAYASIECTTcPxIMEgIAARgBIgQJMt4/EgwSAgABGAEiBAk03D8aAmMxIgsK
  CW90aGVydGVzdCIGCgR0ZXN0KIAgeAI=
 -TA8|GkUKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJNNw/EgwSAgACGAEiBAk03D8aAmMxIgIo
 -ASICKAEiAigCKIAgeAI=
 +TA8|GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
 +ASICKAIogCB4Ag==
  TU2
  ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
  TU3
 Seems to have started happening as result of r15358 commit
 Commit c11837ee6a26f6e42c33a96fe8ae019da93986cc by bjorn
 Expand tests to verify redundant value encoding fix Closes #3741
 git-svn-id: http://svn.osgeo.org/postgis/trunk@15359
 b70326c6-7e19-0410-871a-916f4a2858ee
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742>
