[postgis-tickets] [PostGIS] #3742: mvt regress failure on debbie and winnie
PostGIS trac at osgeo.org
Sat Apr 22 19:41:09 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 On closer inspection doesn't seem to be for all versions of PostgreSQL.
 On debbie - seems like only 9.3 failed.  I'm going to run again just to
 confirm:
  mvt .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.3w64/test_113_diff)
 --- mvt_expected        2017-04-21 17:41:38.547468171 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.3w64/test_113_out
 2017-04-21 18:00:18.839535683 +0000
 @@ -25,8 +25,8 @@
  TA6|GisKBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAigBIgIwASiAIHgC
 TA7|Gk4KBHRlc3QSDBICAAAYASIECTTcPxIMEgIAARgBIgQJMt4/EgwSAgABGAEiBAk03D8aAmMxIgsK
  CW90aGVydGVzdCIGCgR0ZXN0KIAgeAI=
 -TA8|GkUKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJNNw/EgwSAgACGAEiBAk03D8aAmMxIgIo
 -ASICKAEiAigCKIAgeAI=
 +TA8|GkEKBHRlc3QSDBICAAAYASIECTLePxIMEgIAABgBIgQJNNw/EgwSAgABGAEiBAk03D8aAmMxIgIo
 +ASICKAIogCB4Ag==
  TU2
  ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
  TU3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3742#comment:1>
