[postgis-tickets] r16134 - Turn off interrupt tests by default,
Regina Obe lr at pcorp.us
Wed Dec 6 11:34:58 PST 2017
Author: robe
Date: 2017-12-06 11:34:58 -0800 (Wed, 06 Dec 2017)
New Revision: 16134
   trunk/configure.ac
but add to configure an Additional Info section that lists if it's on or off and how to turn it on if its disabled
References #3827 for PostGIS 2.5
Modified: trunk/configure.ac
--- trunk/configure.ac	2017-12-05 22:33:43 UTC (rev 16133)
+++ trunk/configure.ac	2017-12-06 19:34:58 UTC (rev 16134)
@@ -1186,8 +1186,13 @@
                     [Disable the interrupt tests (for CI servers)])],
-if test "x$with_interrupt_tests" != "xno"; then
-    INTERRUPTTESTS="yes"
+AC_ARG_WITH([interrupt-tests],
+    [AS_HELP_STRING([--with-interrupt-tests],
+                    [Enable interrupt tests])],
+    [INTERRUPTTESTS="yes"], [])
+if test "x$with_interrupt_tests" == "xno"; then
+    INTERRUPTTESTS="no"
 fi
 AC_SUBST([INTERRUPTTESTS])
@@ -1472,6 +1477,13 @@
 AC_MSG_RESULT([  C compiler:           ${CC} ${CFLAGS}])
 AC_MSG_RESULT([  SQL preprocessor:     ${SQLPP}])
 AC_MSG_RESULT()
+AC_MSG_RESULT([ -------------- Additional Info ------------- ])
+if test "x$INTERRUPTTESTS" = "xyes"; then
+  AC_MSG_RESULT([  Interrupt Tests:   ENABLED])
+else
+  AC_MSG_RESULT([  Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable])
+fi
+AC_MSG_RESULT()
 AC_MSG_RESULT([ -------------- Dependencies -------------- ])
 AC_MSG_RESULT([  GEOS config:          ${GEOSCONFIG}])
 AC_MSG_RESULT([  GEOS version:         ${GEOS_FULL_VERSION}])
