[postgis-tickets] [PostGIS] #3827: Turn off interrupt tests in configure by default until we can make them work consistently
PostGIS trac at osgeo.org
Wed Dec 6 11:34:59 PST 2017
work consistently
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 In [changeset:"16134" 16134]:
 #!CommitTicketReference repository="" revision="16134"
 Turn off interrupt tests by default,
 but add to configure an Additional Info section that lists if it's on or
 off and how to turn it on if its disabled
 References #3827 for PostGIS 2.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3827#comment:7>
