[postgis-tickets] [PostGIS] #3827: Turn off interrupt tests in configure by default until we can make them work consistently
PostGIS trac at osgeo.org
Wed Dec 6 12:00:21 PST 2017
work consistently
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.3.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16135" 16135]:
 #!CommitTicketReference repository="" revision="16135"
 Turn off interrupt tests in configure by default.
 Also added a section in configure output to note if interrupt tests are
 enabled or not
 Closes #3827 for PostGIS 2.4.3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3827#comment:8>
