[postgis-tickets] [PostGIS] #3952: ST_Transform fails in parallel mode
PostGIS trac at osgeo.org
Sat Dec 23 15:49:40 PST 2017
 Reporter:  pramsey  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.3
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 From an example query:
 ebc_13_17=# create table db_2011 as select st_transform(g.geom,3005) as
 geom, g.dbuid, a.dbpop2011, a.dbtdwell2011, a.dburdwell2011 from
 db_attr_2011 a join db_gis_2011 g using (dbuid) where g.pruid = '59' ;
 ERROR:  cannot start commands during a parallel operation
 CONTEXT:  SQL statement "SELECT proj4text FROM spatial_ref_sys WHERE srid
 = 4326 LIMIT 1"
 Looks like the underlying proj lookup using SPI is not happy w/ the
 parallel executor.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3952>
