[postgis-tickets] [PostGIS] #3952: ST_Transform fails in parallel mode
PostGIS trac at osgeo.org
Sat Dec 23 15:50:06 PST 2017
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Description changed by pramsey:
Old description:
> From an example query:
> ebc_13_17=# create table db_2011 as select st_transform(g.geom,3005) as
> geom, g.dbuid, a.dbpop2011, a.dbtdwell2011, a.dburdwell2011 from
> db_attr_2011 a join db_gis_2011 g using (dbuid) where g.pruid = '59' ;
> ERROR:  cannot start commands during a parallel operation
> CONTEXT:  SQL statement "SELECT proj4text FROM spatial_ref_sys WHERE srid
> = 4326 LIMIT 1"
> Looks like the underlying proj lookup using SPI is not happy w/ the
> parallel executor.
New description:
   select st_transform(g.geom,3005) as geom, g.dbuid, a.dbpop2011,
   from db_attr_2011 a join db_gis_2011 g
 = 4326 LIMIT 1"
 parallel executor.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3952#comment:1>
