[postgis-tickets] [PostGIS] #3661: Mapbox vector tile output support via ST_AsMVT
PostGIS trac at osgeo.org
Mon Feb 6 09:13:46 PST 2017
  Reporter:  Björn Harrtell  |      Owner:  robe
      Type:  enhancement     |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:                  |   Keywords:  history, mvt
Comment (by robe):
 I'm not sure if this is an issue with configure logic or debbie. After the
 protobuf commit r15304  getting this
 checking for shared library run path origin... /bin/bash: ./config.rpath:
 No such file or directory
 done
 checking for CFPreferencesCopyAppValue... no
 checking for CFLocaleCopyCurrent... no
 checking for GNU gettext in libc... yes
 checking whether to use NLS... yes
 checking where the gettext function comes from... libc
 checking proj_api.h usability... yes
 checking proj_api.h presence... yes
 checking for proj_api.h... yes
 checking for pj_get_release in -lproj... yes
 checking json/json.h usability... no
 checking json/json.h presence... no
 checking for json/json.h... no
 checking json-c/json.h usability... yes
 checking json-c/json.h presence... yes
 checking for json-c/json.h... yes
 checking for json_object_get in -ljson-c... yes
 ./configure: line 16565: syntax error near unexpected token `PROTOBUFC,'
 ./configure: line 16565: `PKG_CHECK_MODULES(PROTOBUFC, libprotobuf-c >=
 1.1.0, HAVE_PROTOBUF=yes, HAVE_PROTOBUF=no)'
 Build step 'Execute shell' marked build as failure
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3661#comment:7>
