[postgis-tickets] [PostGIS] #3661: Mapbox vector tile output support via ST_AsMVT
PostGIS trac at osgeo.org
Mon Feb 6 13:34:16 PST 2017
  Reporter:  Björn Harrtell  |      Owner:  robe
      Type:  enhancement     |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.4.0
 Component:  postgis         |    Version:  trunk
Resolution:                  |   Keywords:  history, mvt
Comment (by Björn Harrtell):
 From what I can tell this problem occurs because of the use of
 PKG_CHECK_MODULES. I could not find another suitable method to inspect and
 require the specific version of libprotobuf-c which is the minimum
 required version that can handle the vector tile protobuf specification.
 The specific (unhelpful) error message is given when pkg-config isn't
 installed.
 I'd like to know debbie better, and perhaps also find an alternative to
 PKG_CHECK_MODULES, but for now would it be possible to add pkg-config to
 her? (https://packages.debian.org/search?keywords=pkg-config)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3661#comment:8>
