[postgis-tickets] r15324 - Improve ST_AsMVT documentation
bjorn at wololo.org bjorn at wololo.org
Thu Mar 9 03:30:59 PST 2017
Author: bjornharrtell
Date: 2017-03-09 03:30:59 -0800 (Thu, 09 Mar 2017)
New Revision: 15324
   trunk/doc/reference_output.xml
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml	2017-03-07 20:32:18 UTC (rev 15323)
+++ trunk/doc/reference_output.xml	2017-03-09 11:30:59 UTC (rev 15324)
@@ -1418,7 +1418,7 @@
 		<para>Return a <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink> representation of a set of rows corresponding to a Layer.
 		Multiple calls can be concatenated to a tile with multiple Layers.
 		Geometry is assumed to be in tile coordinate space and valid as per <ulink url="https://www.mapbox.com/vector-tiles/specification/">specification</ulink>.
-		Typically ST_AsMVTGeom can be used to transform geometry into tile coordinate space.
+		Typically <xref linkend="ST_AsMVTGeom" /> can be used to transform geometry into tile coordinate space.
 		Other row data will be encoded as attributes.
 		</para>
@@ -1442,6 +1442,13 @@
 		</programlisting>
 	  </refsection>
+		<refsection>
+			<title>See Also</title>
+				<para>
+					<xref linkend="ST_AsMVTGeom" />
+				</para>
+		  </refsection>
 	</refentry>
   </sect1>
