[postgis-tickets] [PostGIS] #3727: Hard upgrade failed - pg_restore: [archiver] could not find entry for ID 6
PostGIS trac at osgeo.org
Thu Mar 9 04:38:22 PST 2017
 Reporter:  milosh                 |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 2.3.3
Component:  build/upgrade/install  |    Version:  2.3.x
 Keywords:                         |
 I'm trying to hard upgrade spatial db from:
 PostgreSQL 9.3.16, compiled by Visual C++ build 1600, 64-bit
 POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER
 to:
 PostgreSQL 9.6.2, compiled by Visual C++ build 1800, 64-bit POSTGIS="2.3.2
 r15302" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04 March 2015"
 GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8" LIBJSON="0.12"
 TOPOLOGY RASTER
 When running
 perl "%PGINSTALL%\utils\postgis_restore.pl" "%BACKUPFILE%"
 the command prints the following output:
 Converting test_96_upgrade.backup to ASCII on stdout...
   Reading list of functions to ignore...
   Writing manifest of things to read from dump file...
   Writing ASCII to stdout...
 Done.
 No data are restored in the target DB.
 The modified manifest file differs only in:
 +9; 2615 5665374 SCHEMA - topology postgres
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3727>
