[postgis-tickets] r15400 - New function ST_FrechetDistance (patch from Shinichi Sugiyama)
Regina Obe lr at pcorp.us
Mon May 22 21:39:56 PDT 2017
Author: robe
Date: 2017-05-22 21:39:55 -0700 (Mon, 22 May 2017)
New Revision: 15400
Added:
   trunk/regress/frechet.sql
   trunk/regress/frechet_expected
   trunk/NEWS
   trunk/doc/reference_measure.xml
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/postgis.sql.in
   trunk/regress/Makefile.in
   trunk/utils/postgis_restore.pl.in
Closes #3677
Closes https://github.com/postgis/postgis/pull/120
Modified: trunk/NEWS
--- trunk/NEWS	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/NEWS	2017-05-23 04:39:55 UTC (rev 15400)
@@ -8,6 +8,7 @@
   - #3689, Add orientation checking and forcing functions (Dan Baston)
   - #3753, Gist penalty speed improvements for 2d and nd points
            (Darafei Praliaskouski)
+  - #3677, ST_FrechetDistance (Shinichi Sugiyama)
  * Bug Fixes *
   - #3682, Boolean (FTLogical) should be 1 byte not 2 bytes
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/doc/reference_measure.xml	2017-05-23 04:39:55 UTC (rev 15400)
@@ -2598,8 +2598,84 @@
 			</programlisting>
 	  </refsection>
+          <refsection>
+                <title>See Also</title>
+                <para><xref linkend="ST_FrechetDistance" /></para>
+          </refsection>
 	</refentry>
+	<refentry id="ST_FrechetDistance">
+	  <refnamediv>
+		<refname>ST_FrechetDistance</refname>
+		<refpurpose>Returns the Fréchet distance between two geometries. This is a measure of similarity between curves that takes into account the location
+		and ordering of the points along the curves.  Units are in the units of the spatial reference system of the geometries.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>float <function>ST_FrechetDistance</function></funcdef>
+			<paramdef><type>geometry </type>
+			<parameter>g1</parameter></paramdef>
+			<parameter>g2</parameter></paramdef>
+			<paramdef><type>float</type>
+			<parameter>densifyFrac = -1</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>Implements algorithm for computing the Fréchet distance restricted to discrete points for both geometries, based on <ulink url="http://www.kr.tuwien.ac.at/staff/eiter/et-archive/cdtr9464.pdf">Computing Discrete Fréchet Distance</ulink>.
+		The Fréchet distance is a measure of similarity between curves that takes into account the location and ordering of the points along the curves. Therefore it is often better than the Hausdorff distance. </para>
+		<para>
+When the optional densifyFrac is specified, this function performs a segment densification before computing the discrete Fréchet distance. The densifyFrac parameter sets the fraction by which to densify each segment. Each segment will be split into a number of equal-length subsegments, whose fraction of the total length is closest to the given fraction.
+		</para>
+		<note>
+			<para>
+The current implementation supports only vertices as the discrete locations. This could be extended to allow an arbitrary density of points to be used.
+			</para>
+		</note>
+		<note>
+			<para>
+The smaller densifyFrac we specify, the more acurate Fréchet distance we get. But, the computation time and the memory usage increase with the square of the number of subsegments.
+			</para>
+		</note>
+		<para>Availability: 2.4.0 - requires GEOS >= 3.7.0</para>
+	  </refsection>
+	  <refsection>
+		<title>Examples</title>
+			<programlisting>postgres=# SELECT st_frechetdistance('LINESTRING (0 0, 100 0)'::geometry, 'LINESTRING (0 0, 50 50, 100 0)'::geometry);
+ st_frechetdistance
+   70.7106781186548
+(1 row)
+			</programlisting>
+			<programlisting>SELECT st_frechetdistance('LINESTRING (0 0, 100 0)'::geometry, 'LINESTRING (0 0, 50 50, 100 0)'::geometry, 0.5);
+                 50
+(1 row)
+			</programlisting>
+	  </refsection>
+	  <refsection>
+		<para><xref linkend="ST_HausdorffDistance" /></para>
+	  </refsection>
+	</refentry>
 <refentry id="ST_MaxDistance">
   <refnamediv>
     <refname>ST_MaxDistance</refname>
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/postgis/lwgeom_geos.c	2017-05-23 04:39:55 UTC (rev 15400)
@@ -99,6 +99,7 @@
 Datum coveredby(PG_FUNCTION_ARGS);
 Datum hausdorffdistance(PG_FUNCTION_ARGS);
 Datum hausdorffdistancedensify(PG_FUNCTION_ARGS);
+Datum ST_FrechetDistance(PG_FUNCTION_ARGS);
 Datum ST_UnaryUnion(PG_FUNCTION_ARGS);
 Datum ST_Equals(PG_FUNCTION_ARGS);
 Datum ST_BuildArea(PG_FUNCTION_ARGS);
@@ -279,8 +280,83 @@
 	PG_RETURN_FLOAT8(result);
+ *  @brief Compute the Frechet distance with optional densification thanks to the corresponding GEOS function
+ *  @example ST_FrechetDistance {@link #frechetdistance} - SELECT ST_FrechetDistance(
+ *      'LINESTRING (0 0, 50 200, 100 0, 150 200, 200 0)'::geometry,
+ *      'LINESTRING (0 200, 200 150, 0 100, 200 50, 0 0)'::geometry, 0.5);
+PG_FUNCTION_INFO_V1(ST_FrechetDistance);
+#if POSTGIS_GEOS_VERSION < 37
+	lwpgerror("The GEOS version this PostGIS binary "
+					"was compiled against (%d) doesn't support "
+					"'GEOSFechetDistance' function (3.7.0+ required)",
+					POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 37 */
+	GSERIALIZED *geom1;
+	GSERIALIZED *geom2;
+	GEOSGeometry *g1;
+	GEOSGeometry *g2;
+	double densifyFrac;
+	double result;
+	int retcode;
+	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	geom2 = PG_GETARG_GSERIALIZED_P(1);
+	densifyFrac = PG_GETARG_FLOAT8(2);
+	if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
+		PG_RETURN_NULL();
+	initGEOS(lwpgnotice, lwgeom_geos_error);
+	g1 = (GEOSGeometry *)POSTGIS2GEOS(geom1);
+	if ( 0 == g1 )   /* exception thrown at construction */
+		HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
+		PG_RETURN_NULL();
+	g2 = (GEOSGeometry *)POSTGIS2GEOS(geom2);
+	if ( 0 == g2 )   /* exception thrown at construction */
+		HANDLE_GEOS_ERROR("Second argument geometry could not be converted to GEOS");
+		GEOSGeom_destroy(g1);
+		PG_RETURN_NULL();
+	if (densifyFrac <= 0.0)
+		retcode = GEOSFrechetDistance(g1, g2, &result);
+	else
+		retcode = GEOSFrechetDistanceDensify(g1, g2, densifyFrac, &result);
+	GEOSGeom_destroy(g2);
+	if (retcode == 0)
+		HANDLE_GEOS_ERROR("GEOSFrechetDistance");
+		PG_RETURN_NULL(); /*never get here */
+	PG_FREE_IF_COPY(geom1, 0);
+	PG_FREE_IF_COPY(geom2, 1);
+	PG_RETURN_FLOAT8(result);
+#endif /* POSTGIS_GEOS_VERSION >= 37 */
  * @brief This is the final function for GeomUnion
  * 			aggregate. Will have as input an array of Geometries.
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/postgis/postgis.sql.in	2017-05-23 04:39:55 UTC (rev 15400)
@@ -3452,6 +3452,14 @@
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
 	COST 100; -- Guessed cost
+-- Requires GEOS >= 3.7.0
+-- Availability: 2.4.0
+CREATE OR REPLACE FUNCTION ST_FrechetDistance(geom1 geometry, geom2 geometry, float8 default -1)
+       RETURNS FLOAT8
+       AS 'MODULE_PATHNAME', 'ST_FrechetDistance'
+       LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
+       COST 100; -- Guessed cost
 -- PostGIS equivalent function: difference(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry)
 	RETURNS geometry
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/regress/Makefile.in	2017-05-23 04:39:55 UTC (rev 15400)
@@ -167,6 +167,13 @@
 		regress_buffer_params
 endif
+ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 37),1)
+	# GEOS-3.7 adds:
+	# ST_FrechetDistance
+	TESTS += \
+		frechet
+endif
 ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 33),1)
 	# GEOS-3.3 adds:
 	# ST_RelateMatch, ST_IsValidDetail, ST_SharedPaths ,
Added: trunk/regress/frechet.sql
--- trunk/regress/frechet.sql	                        (rev 0)
+++ trunk/regress/frechet.sql	2017-05-23 04:39:55 UTC (rev 15400)
@@ -0,0 +1,31 @@
+-- tests for Frechet distances
+-- linestring and linestring
+SELECT 'frechet_ls_ls', st_frechetdistance(
+	'LINESTRING (0 0, 2 1)'::geometry
+	, 'LINESTRING (0 0, 2 0)'::geometry);
+-- 1.0
+-- other linestrings
+SELECT 'frechet_ls_ls_2', st_frechetdistance(
+	'LINESTRING (0 0, 2 0)'::geometry,
+	'LINESTRING (0 1, 1 2, 2 1)'::geometry);
+-- 2.23606797749979
+-- linestring and multipoint
+SELECT 'frechet_ls_mp', st_frechetdistance(
+	'MULTIPOINT (0 1, 1 0, 2 1)'::geometry);
+-- 1.0
+-- another linestring and linestring
+SELECT 'frechet_ls_ls_3', st_frechetdistance(
+	'LINESTRING (0 0, 100 0)'::geometry,
+	'LINESTRING (0 0, 50 50, 100 0)'::geometry);
+-- 70.7106781186548
+-- rechet with densification
+SELECT 'frechetdensify_ls_ls', st_frechetdistance(
+	'LINESTRING (0 0, 50 50, 100 0)'::geometry, 0.5);
+-- 50.0
Added: trunk/regress/frechet_expected
--- trunk/regress/frechet_expected	                        (rev 0)
+++ trunk/regress/frechet_expected	2017-05-23 04:39:55 UTC (rev 15400)
@@ -0,0 +1,5 @@
+frechet_ls_ls|1
+frechet_ls_ls_2|2.23606797749979
+frechet_ls_mp|1
+frechet_ls_ls_3|70.7106781186548
+frechetdensify_ls_ls|50
Modified: trunk/utils/postgis_restore.pl.in
--- trunk/utils/postgis_restore.pl.in	2017-05-22 16:36:11 UTC (rev 15399)
+++ trunk/utils/postgis_restore.pl.in	2017-05-23 04:39:55 UTC (rev 15400)
@@ -899,6 +899,10 @@
 COMMENT FUNCTION st_force_4d(geometry)
 COMMENT FUNCTION st_force_collection(geometry)
 COMMENT FUNCTION st_forcerhr(geometry)
+COMMENT FUNCTION st_frechetdistance(geom1 geometry,geom2 geometry)
+COMMENT FUNCTION st_frechetdistance(geom1 geometry,geom2 geometry,double precision)
+COMMENT FUNCTION st_frechetdistance(geometry,geometry)
+COMMENT FUNCTION st_frechetdistance(geometry,geometry,double precision)
 COMMENT FUNCTION st_gdaldrivers(OUTidxinteger,OUTshort_nametext,OUTlong_nametext,OUTcreate_optionstext)
 COMMENT FUNCTION st_geogfromtext(text)
 COMMENT FUNCTION st_geogfromwkb(bytea)
