[postgis-tickets] r15401 - #3758, regression failure on stats. Add test data as static COPY,
Paul Ramsey pramsey at cleverelephant.ca
Wed May 24 11:55:17 PDT 2017
Author: pramsey
Date: 2017-05-24 11:55:17 -0700 (Wed, 24 May 2017)
New Revision: 15401
   trunk/postgis/gserialized_estimate.c
   trunk/regress/regress_selectivity.sql
not dynamic generation, since change in generate_series caused probs
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c	2017-05-23 04:39:55 UTC (rev 15400)
+++ trunk/postgis/gserialized_estimate.c	2017-05-24 18:55:17 UTC (rev 15401)
@@ -824,7 +824,7 @@
 	/* If we're in 2D mode, set the kind appropriately */
 	if ( mode == 2 ) stats_kind = STATISTIC_KIND_2D;
-  /* Then read the geom status histogram from that */
+    /* Then read the geom status histogram from that */
 #if POSTGIS_PGSQL_VERSION < 100
 	float4 *floatptr;
@@ -845,9 +845,9 @@
 	/* Clean up */
 	free_attstatsslot(0, NULL, 0, floatptr, nvalues);
-#else /**10 or higher **/
+#else /* PostgreSQL 10 or higher */
 	AttStatsSlot sslot;
-	rv = get_attstatsslot(&sslot,stats_tuple, stats_kind, InvalidOid,
+	rv = get_attstatsslot(&sslot, stats_tuple, stats_kind, InvalidOid,
 						 ATTSTATSSLOT_NUMBERS);
 	if ( ! rv ) {
 		POSTGIS_DEBUGF(2,
@@ -856,13 +856,13 @@
 	/* Clone the stats here so we can release the attstatsslot immediately */
-	nd_stats = palloc(sizeof(float) * sslot.nnumbers);
-	memcpy(nd_stats,  sslot.numbers, sizeof(float) * sslot.nnumbers);
+	nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
+	memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
 	free_attstatsslot(&sslot);
 #endif
-  return nd_stats;
+    return nd_stats;
Modified: trunk/regress/regress_selectivity.sql
--- trunk/regress/regress_selectivity.sql	2017-05-23 04:39:55 UTC (rev 15400)
+++ trunk/regress/regress_selectivity.sql	2017-05-24 18:55:17 UTC (rev 15401)
@@ -1,4 +1,2141 @@
+-- Make example data
+CREATE TABLE regular_overdots_ab (
+    a integer,
+    b integer
+COPY regular_overdots_ab (a, b) FROM stdin;
+1	1
+1	1
+1	2
+1	1
+1	2
+1	3
+1	1
+1	2
+1	3
+1	4
+1	1
+1	2
+1	3
+1	4
+1	5
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	9
+1	1
+1	2
+1	3
+1	4
+1	5
+1	6
+1	7
+1	8
+1	9
+1	10
+1	1
+2	1
+1	1
+2	2
+1	1
+2	2
+1	3
+2	1
+1	2
+2	3
+1	1
+2	2
+1	3
+2	4
+1	1
+2	2
+1	3
+2	4
+1	5
+2	1
+1	2
+2	3
+1	4
+2	5
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	1
+1	2
+2	3
+1	4
+2	5
+1	6
+2	7
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	9
+2	1
+1	2
+2	3
+1	4
+2	5
+1	6
+2	7
+1	8
+2	9
+1	1
+2	2
+1	3
+2	4
+1	5
+2	6
+1	7
+2	8
+1	9
+2	10
+1	1
+2	1
+3	1
+1	1
+2	2
+3	1
+1	2
+2	1
+3	2
+1	1
+2	2
+3	3
+1	1
+2	2
+3	3
+1	4
+2	1
+3	2
+1	3
+2	4
+3	1
+1	2
+2	3
+3	4
+1	1
+2	2
+3	3
+1	4
+2	5
+3	1
+1	2
+2	3
+3	4
+1	5
+2	1
+3	2
+1	3
+2	4
+3	5
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	8
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	8
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	9
+1	1
+2	2
+3	3
+1	4
+2	5
+3	6
+1	7
+2	8
+3	9
+1	10
+2	1
+3	2
+1	3
+2	4
+3	5
+1	6
+2	7
+3	8
+1	9
+2	10
+3	1
+1	2
+2	3
+3	4
+1	5
+2	6
+3	7
+1	8
+2	9
+3	10
+1	1
+2	1
+3	1
+4	1
+1	1
+2	2
+3	1
+4	2
+1	1
+2	2
+3	3
+4	1
+1	2
+2	3
+3	1
+4	2
+1	3
+2	1
+3	2
+4	3
+1	1
+2	2
+3	3
+4	4
+1	1
+2	2
+3	3
+4	4
+1	5
+2	1
+3	2
+4	3
+1	4
+2	5
+3	1
+4	2
+1	3
+2	4
+3	5
+4	1
+1	2
+2	3
+3	4
+4	5
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	1
+1	2
+2	3
+3	4
+4	5
+1	6
+2	7
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	1
+3	2
+4	3
+1	4
+2	5
+3	6
+4	7
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	9
+2	1
+3	2
+4	3
+1	4
+2	5
+3	6
+4	7
+1	8
+2	9
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	8
+3	9
+4	1
+1	2
+2	3
+3	4
+4	5
+1	6
+2	7
+3	8
+4	9
+1	1
+2	2
+3	3
+4	4
+1	5
+2	6
+3	7
+4	8
+1	9
+2	10
+3	1
+4	2
+1	3
+2	4
+3	5
+4	6
+1	7
+2	8
+3	9
+4	10
+1	1
+2	1
+3	1
+4	1
+5	1
+1	1
+2	2
+3	1
+4	2
+5	1
+1	2
+2	1
+3	2
+4	1
+5	2
+1	1
+2	2
+3	3
+4	1
+5	2
+1	3
+2	1
+3	2
+4	3
+5	1
+1	2
+2	3
+3	1
+4	2
+5	3
+1	1
+2	2
+3	3
+4	4
+5	1
+1	2
+2	3
+3	4
+4	1
+5	2
+1	3
+2	4
+3	1
+4	2
+5	3
+1	4
+2	1
+3	2
+4	3
+5	4
+1	1
+2	2
+3	3
+4	4
+5	5
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	8
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	8
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	8
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	8
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	9
+5	1
+1	2
+2	3
+3	4
+4	5
+5	6
+1	7
+2	8
+3	9
+4	1
+5	2
+1	3
+2	4
+3	5
+4	6
+5	7
+1	8
+2	9
+3	1
+4	2
+5	3
+1	4
+2	5
+3	6
+4	7
+5	8
+1	9
+2	1
+3	2
+4	3
+5	4
+1	5
+2	6
+3	7
+4	8
+5	9
+1	1
+2	2
+3	3
+4	4
+5	5
+1	6
+2	7
+3	8
+4	9
+5	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+1	2
+2	1
+3	2
+4	1
+5	2
+6	1
+7	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+1	4
+2	1
+3	2
+4	3
+5	4
+6	1
+7	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+1	2
+2	3
+3	4
+4	1
+5	2
+6	3
+7	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+1	8
+2	9
+3	10
+4	1
+5	2
+6	3
+7	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+1	6
+2	7
+3	8
+4	9
+5	10
+6	1
+7	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+1	10
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+8	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+8	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+8	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+8	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+8	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+8	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+8	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+8	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+8	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+8	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+9	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+9	1
+1	2
+2	1
+3	2
+4	1
+5	2
+6	1
+7	2
+8	1
+9	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+9	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+9	1
+1	2
+2	3
+3	4
+4	1
+5	2
+6	3
+7	4
+8	1
+9	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+8	2
+9	3
+1	4
+2	1
+3	2
+4	3
+5	4
+6	1
+7	2
+8	3
+9	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+9	4
+1	5
+2	1
+3	2
+4	3
+5	4
+6	5
+7	1
+8	2
+9	3
+1	4
+2	5
+3	1
+4	2
+5	3
+6	4
+7	5
+8	1
+9	2
+1	3
+2	4
+3	5
+4	1
+5	2
+6	3
+7	4
+8	5
+9	1
+1	2
+2	3
+3	4
+4	5
+5	1
+6	2
+7	3
+8	4
+9	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	8
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	8
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+1	10
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+1	9
+2	10
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+1	8
+2	9
+3	10
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+1	7
+2	8
+3	9
+4	10
+5	1
+6	2
+7	3
+8	4
+9	5
+1	6
+2	7
+3	8
+4	9
+5	10
+6	1
+7	2
+8	3
+9	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	10
+7	1
+8	2
+9	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	10
+8	1
+9	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	10
+9	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+9	10
+1	1
+2	1
+3	1
+4	1
+5	1
+6	1
+7	1
+8	1
+9	1
+10	1
+1	1
+2	2
+3	1
+4	2
+5	1
+6	2
+7	1
+8	2
+9	1
+10	2
+1	1
+2	2
+3	3
+4	1
+5	2
+6	3
+7	1
+8	2
+9	3
+10	1
+1	2
+2	3
+3	1
+4	2
+5	3
+6	1
+7	2
+8	3
+9	1
+10	2
+1	3
+2	1
+3	2
+4	3
+5	1
+6	2
+7	3
+8	1
+9	2
+10	3
+1	1
+2	2
+3	3
+4	4
+5	1
+6	2
+7	3
+8	4
+9	1
+10	2
+1	3
+2	4
+3	1
+4	2
+5	3
+6	4
+7	1
+8	2
+9	3
+10	4
+1	1
+2	2
+3	3
+4	4
+5	5
+6	1
+7	2
+8	3
+9	4
+10	5
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	1
+9	2
+10	3
+1	4
+2	5
+3	6
+4	7
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	1
+7	2
+8	3
+9	4
+10	5
+1	6
+2	7
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+10	7
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	8
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	8
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	8
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+10	1
+1	2
+2	3
+3	4
+4	5
+5	6
+6	7
+7	8
+8	9
+9	1
+10	2
+1	3
+2	4
+3	5
+4	6
+5	7
+6	8
+7	9
+8	1
+9	2
+10	3
+1	4
+2	5
+3	6
+4	7
+5	8
+6	9
+7	1
+8	2
+9	3
+10	4
+1	5
+2	6
+3	7
+4	8
+5	9
+6	1
+7	2
+8	3
+9	4
+10	5
+1	6
+2	7
+3	8
+4	9
+5	1
+6	2
+7	3
+8	4
+9	5
+10	6
+1	7
+2	8
+3	9
+4	1
+5	2
+6	3
+7	4
+8	5
+9	6
+10	7
+1	8
+2	9
+3	1
+4	2
+5	3
+6	4
+7	5
+8	6
+9	7
+10	8
+1	9
+2	1
+3	2
+4	3
+5	4
+6	5
+7	6
+8	7
+9	8
+10	9
+1	1
+2	2
+3	3
+4	4
+5	5
+6	6
+7	7
+8	8
+9	9
+10	10
 -- Check for error messages
 create table no_stats ( g geometry, id integer );
 create table no_stats_join ( g geometry, id integer );
@@ -8,15 +2145,12 @@
 insert into no_stats (g, id) values ('POINT(0 0)', 0);
 analyze no_stats;
 select _postgis_join_selectivity('no_stats', 'g', 'no_stats_join', 'g');
-drop table no_stats;
-drop table no_stats_join;
+drop table if exists no_stats;
+drop table if exists no_stats_join;
 -- Table with uniformly variable density, highest at 1,1, lowest at 10,10
 create table regular_overdots as
-with
-ij as ( select i, j from generate_series(1, 10) i, generate_series(1, 10) j),
-iijj as (select generate_series(1, i) as a, generate_series(1, j) b from ij)
-select st_makepoint(a, b) as g from iijj;
+  select st_makepoint(a, b) as g from regular_overdots_ab;
 -- Generate the stats
 analyze regular_overdots;
@@ -49,4 +2183,5 @@
 -- Clean
 drop table if exists regular_overdots;
+drop table if exists regular_overdots_ab;
