[postgis-tickets] [PostGIS] #3759: PostgreSQL 10 failure on winnie both raster and geometry
PostGIS trac at osgeo.org
Thu May 25 12:37:38 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:  postgresql 10
Comment (by robe):
 Just tested on debbie's 10beta1 and raster seems okay but get same error
 on geometry:
 tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
 --- tickets_expected    2016-09-26 01:59:38 -0400
 /projects/postgis/tmp/2.4.0dev_pg10_geos3.7.0dev_gdal2.1.3w64/test_89_out
 2017-05-25 15:15:09 -0400
 @@ -285,7 +285,7 @@
  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
  #3399|1|1
  #3399|10|10
 -#3399|100|100
 +#3399|100|99
  #3399|1000|1000
  ERROR:  invalid KML representation
  #3437a|5
 On my windows box, I'm getting the same errors as winnie with raster.  So
 something has changed, and I'm pretty sure I tested this after I committed
 fix and it was only regress selectivity failing.
 So I think something about r15401 caused this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3759#comment:1>
