[postgis-tickets] [PostGIS] #3759: PostgreSQL 10 failure on winnie both raster and geometry
PostGIS trac at osgeo.org
Thu May 25 12:51:56 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:  postgresql 10
Comment (by robe):
 Aha smoking gun at least for the postgis regression.  The raster
 regression might always have been there wasn't seen because of the
 selectivity failure might have been preventing raster tests.
 the geometry regression in tickets caused by this change
  nd_stats = palloc(sizeof(float) * sslot.nnumbers);
  memcpy(nd_stats, sslot.numbers, sizeof(float) * sslot.nnumbers);
 To:
  nd_stats = palloc(sizeof(float4) * sslot.nnumbers);
  memcpy(nd_stats, sslot.numbers, sizeof(float4) * sslot.nnumbers);
 @pramsey - this change was not documented in your commit notes, was there
 a reason for it?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3759#comment:2>
