[postgis-tickets] r15407 - Change log table name
Regina Obe lr at pcorp.us
Sat May 27 06:34:23 PDT 2017
Author: robe
Date: 2017-05-27 06:34:23 -0700 (Sat, 27 May 2017)
New Revision: 15407
   trunk/doc/xsl/postgis_gardentest.sql.xsl
   trunk/doc/xsl/raster_gardentest.sql.xsl
Modified: trunk/doc/xsl/postgis_gardentest.sql.xsl
--- trunk/doc/xsl/postgis_gardentest.sql.xsl	2017-05-26 19:35:19 UTC (rev 15406)
+++ trunk/doc/xsl/postgis_gardentest.sql.xsl	2017-05-27 13:34:23 UTC (rev 15407)
@@ -8,7 +8,7 @@
 			using a garden variety of geometries.  Its intent is to flag major crashes.
 	<xsl:output method="text" />
-	<xsl:variable name='testversion'>2.3.0</xsl:variable>
+	<xsl:variable name='testversion'>2.4.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
@@ -31,7 +31,7 @@
 	<xsl:variable name='var_spheroid'>'SPHEROID["GRS_1980",6378137,298.257222101]'</xsl:variable>
 	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
 	<xsl:variable name='var_boolean'>false</xsl:variable>
-	<xsl:variable name='var_logtable'>postgis_garden_log23</xsl:variable>
+	<xsl:variable name='var_logtable'>postgis_garden_log24</xsl:variable>
 	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
 		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
 		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
Modified: trunk/doc/xsl/raster_gardentest.sql.xsl
--- trunk/doc/xsl/raster_gardentest.sql.xsl	2017-05-26 19:35:19 UTC (rev 15406)
+++ trunk/doc/xsl/raster_gardentest.sql.xsl	2017-05-27 13:34:23 UTC (rev 15407)
@@ -8,7 +8,7 @@
 			using a garden variety of rasters.  Its intent is to flag major crashes.
-	<xsl:variable name='testversion'>2.2.0</xsl:variable>
 	<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@ -31,7 +31,7 @@
 	<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
 	<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
-	<xsl:variable name='var_logtable'>raster_garden_log22</xsl:variable>
+	<xsl:variable name='var_logtable'>raster_garden_log24</xsl:variable>
 	<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
 	<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
 	<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
