[postgis-tickets] [PostGIS] #3765: geometry regress failure
PostGIS trac at osgeo.org
Sat May 27 10:04:33 PDT 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 2.4.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Description changed by robe:
Old description:
> I thought the issue in #3759 was a PostgreSQL 10 one which mysteriously
> disappeared.
> But now our seeing it on winnie in her 9.5 run, but a different record
> different.
> Checking for shp2pgsql ... found
> Checking for pgsql2shp ... found
> Checking for raster2pgsql ... found
> TMPDIR is /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64
> Creating database 'postgis_reg'
> Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
> PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit
>   Postgis 2.4.0dev - r15406 - 2017-05-26 20:07:15
>   scripts 2.4.0dev r15406
>   raster scripts 2.4.0dev r15406
>   GEOS: 3.7.0dev-CAPI-1.11.0 8fe2ce6
>   PROJ: Rel. 4.9.1, 04 March 2015
>   SFCGAL: 1.3.0
>   GDAL: GDAL 2.1.3, released 2017/20/01
> tickets .. failed (diff expected obtained:
> /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64/test_89_diff)
> --- tickets_expected    2016-09-26 01:59:38 -0400
> /projects/postgis/tmp/2.4.0dev_pg9.5_geos3.7.0dev_gdal2.1.3w64/test_89_out
> 2017-05-26 16:13:04 -0400
> @@ -284,7 +284,7 @@
> #3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
>  #3375|GEOMETRYCOLLECTION(POINT(0 -7))
>  #3399|1|1
> -#3399|10|10
> +#3399|10|9
>  #3399|100|100
>  #3399|1000|1000
>  ERROR:  invalid KML representation
> Might be bot specific I guess but still concerning.
> Problem is intermittent.  I did a manual run and it passed.  So perhaps
> some dirty memory somewhere.
New description:
 disappeared.
 different.
   SFCGAL: 1.3.0
 @@ -284,7 +284,7 @@
  #3399|1|1
 -#3399|10|10
 +#3399|10|9
  #3399|100|100
  #3399|1000|1000
 Problem query is:
 -- #3399
 WITH g as (
 select 'POLYGON((1 0, 0 1, 1 2, 2 1, 1 0))'::geometry as geom
 n as (
 select n from unnest(ARRAY[-1,0,1,10,100,1000]) n
 pts as (
   select n,(st_dump(st_generatepoints(geom, n))).geom from g,n
 select '#3399' as t, n, count(*) from
 g, pts
 where st_contains(g.geom, pts.geom)
 group by n
 ORDER BY n;
 Problem is intermittent.  I did a manual run multiple times and it passed.
 So perhaps some dirty memory somewhere or only happens if system is taxed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3765#comment:2>
