[postgis-tickets] r15408 - replace tabs with spaces from last commit
Regina Obe lr at pcorp.us
Sat May 27 09:40:48 PDT 2017
Author: robe
Date: 2017-05-27 09:40:48 -0700 (Sat, 27 May 2017)
New Revision: 15408
   trunk/topology/sql/topogeometry/totopogeom.sql.in
Modified: trunk/topology/sql/topogeometry/totopogeom.sql.in
--- trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-05-27 13:34:23 UTC (rev 15407)
+++ trunk/topology/sql/topogeometry/totopogeom.sql.in	2017-05-27 16:40:48 UTC (rev 15408)
@@ -240,11 +240,11 @@
     FROM (SELECT (ST_Dump(ageom)).geom) as f
     WHERE NOT ST_IsEmpty(geom)
   LOOP
-  	-- NOTE: storing this as a constant
-  	-- because the CASE WHEN in PostgreSQL 10 refuses to short-circuit
-  	-- when CASE contains set returning functions and the CASE boolean is not a constant
-  	-- TODO: this feels a little dirty to assume so may need a revisit in near future
-  	var_dims = rec.dims;
+    -- NOTE: storing this as a constant
+    -- because the CASE WHEN in PostgreSQL 10 refuses to short-circuit
+    -- when CASE contains set returning functions and the CASE boolean is not a constant
+    -- TODO: this feels a little dirty to assume so may need a revisit in near future
+    var_dims = rec.dims;
     FOR rec2 IN SELECT CASE var_dims
        WHEN 0 THEN
          topology.topogeo_addPoint(atopology, rec.geom, tolerance)
