[postgis-tickets] r15409 - List parent partition tables and have geography_view only list things like tables (exclude helper types)
Regina Obe lr at pcorp.us
Sat May 27 10:07:42 PDT 2017
Author: robe
Date: 2017-05-27 10:07:42 -0700 (Sat, 27 May 2017)
New Revision: 15409
   trunk/postgis/geography.sql.in
   trunk/postgis/postgis.sql.in
   trunk/raster/rt_pg/rtpostgis.sql.in
Closes #3766
Modified: trunk/postgis/geography.sql.in
--- trunk/postgis/geography.sql.in	2017-05-27 16:40:48 UTC (rev 15408)
+++ trunk/postgis/geography.sql.in	2017-05-27 17:07:42 UTC (rev 15409)
@@ -147,6 +147,7 @@
 	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
 -- Availability: 1.5.0
+-- Changed: 2.4.0 Limit to only list things that are tables
 CREATE OR REPLACE VIEW geography_columns AS
 	SELECT
 		current_database() AS f_table_catalog,
@@ -162,12 +163,13 @@
 		pg_type t,
 		pg_namespace n
 	WHERE t.typname = 'geography'
-        AND a.attisdropped = false
-        AND a.atttypid = t.oid
-        AND a.attrelid = c.oid
-        AND c.relnamespace = n.oid
-        AND NOT pg_is_other_temp_schema(c.relnamespace)
-        AND has_table_privilege( c.oid, 'SELECT'::text );
+		AND a.attisdropped = false
+		AND a.atttypid = t.oid
+		AND a.attrelid = c.oid
+		AND c.relnamespace = n.oid
+		AND c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"] )
+		AND NOT pg_is_other_temp_schema(c.relnamespace)
+		AND has_table_privilege( c.oid, 'SELECT'::text );
 CREATE OR REPLACE FUNCTION geography(geometry)
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2017-05-27 16:40:48 UTC (rev 15408)
+++ trunk/postgis/postgis.sql.in	2017-05-27 17:07:42 UTC (rev 15409)
@@ -5433,7 +5433,8 @@
 -- Availability: 2.0.0
 -- Changed: 2.1.8 significant performance improvement for constraint based columns
--- Changed: 2.2.0 get rid of scheman, table, column cast to improve performance
+-- Changed: 2.2.0 get rid of schema, table, column cast to improve performance
+-- Changed: 2.4.0 List also Parent partitioned tables
 CREATE OR REPLACE VIEW geometry_columns AS
  SELECT current_database()::character varying(256) AS f_table_catalog,
     n.nspname AS f_table_schema,
@@ -5467,7 +5468,7 @@
           WHERE s.consrc ~~* '%srid(% = %'::text
 ) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
-  WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char"]))
+  WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
   AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
   AND NOT pg_is_other_temp_schema(c.relnamespace) AND has_table_privilege(c.oid, 'SELECT'::text);
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in	2017-05-27 16:40:48 UTC (rev 15408)
+++ trunk/raster/rt_pg/rtpostgis.sql.in	2017-05-27 17:07:42 UTC (rev 15409)
@@ -8250,6 +8250,7 @@
 -- Changed: 2.2.0
+-- Changed: 2.4.0 List partitioned parent tables
 CREATE OR REPLACE VIEW raster_columns AS
 	SELECT
 		current_database() AS r_table_catalog,
@@ -8279,7 +8280,7 @@
-		AND c.relkind = ANY(ARRAY['r'::char, 'v'::char, 'm'::char, 'f'::char])
