[postgis-tickets] [PostGIS] #3767: SQL file indentations are mixed
PostGIS trac at osgeo.org
Sat May 27 10:10:16 PDT 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  low      |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 On the postgis.sql.in we've got a mix of tabs and spaces
 rtpostgis.sql.in and geography.sql.in are mostly tab spaced.
 topology is mostly spaces I think.
 and then we've got true .sql files.
 I think sql.in and .sql should have the same indentation.
 I prefer tabs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3767>
