[postgis-tickets] [PostGIS] #3767: SQL file indentations are mixed
PostGIS trac at osgeo.org
Sat May 27 10:11:41 PDT 2017
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  low      |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by robe):
 * owner:  pramsey => strk
Old description:
> On the postgis.sql.in we've got a mix of tabs and spaces
> rtpostgis.sql.in and geography.sql.in are mostly tab spaced.
> topology is mostly spaces I think.
> and then we've got true .sql files.
> I think sql.in and .sql should have the same indentation.
> I prefer tabs.
New description:
 I prefer tabs.
 Should standardize and editorconfig should be updated to reflect
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3767#comment:1>
