[postgis-tickets] r16118 - Explicitly specify $(PERL) to call create_unpackaged.pl otherwise at least on freebsd it fails
Regina Obe lr at pcorp.us
Tue Nov 28 14:17:51 PST 2017
Author: robe
Date: 2017-11-28 14:17:51 -0800 (Tue, 28 Nov 2017)
New Revision: 16118
   trunk/extensions/postgis_sfcgal/Makefile.in
References #3938 for PostGIS 2.5
Modified: trunk/extensions/postgis_sfcgal/Makefile.in
--- trunk/extensions/postgis_sfcgal/Makefile.in	2017-11-25 07:38:52 UTC (rev 16117)
+++ trunk/extensions/postgis_sfcgal/Makefile.in	2017-11-28 22:17:51 UTC (rev 16118)
@@ -64,7 +64,7 @@
 #then remove default values and extra junk
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/sfcgal.sql ../../utils/create_unpackaged.pl
 	mkdir -p sql
-	cat $< | ../../utils/create_unpackaged.pl ${EXTENSION} > $@
+	cat $< |  $(PERL) ../../utils/create_unpackaged.pl ${EXTENSION} > $@
 sql_bits/sfcgal_upgrade.sql : ../../postgis/sfcgal_upgrade.sql
 	mkdir -p sql_bits
