[postgis-tickets] [PostGIS] #3938: Bessie FreeBSD and SFCGAL build unpackaged script issue
PostGIS trac at osgeo.org
Tue Nov 28 17:12:38 PST 2017
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.3.6
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:  fixed                  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16124" 16124]:
 #!CommitTicketReference repository="" revision="16124"
 Explicitly specify $(PERL) to call create_unpackaged.pl otherwise at least
 on freebsd it fails (and backport other minor changes like remove of 9.1
 which support was dropped in 2.2)
 Closes #3938 for PostGIS 2.3.6
 Also add the Bessie sisters to battery testing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3938#comment:6>
