[postgis-tickets] [PostGIS] #3839: shp2pgsql cunit tests failing on Windows
PostGIS trac at osgeo.org
Sat Sep 9 09:37:04 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I thoughts this was just something wrong about the way I configured
> things on winnie's 32-bit runs, but now I have the same issue on my local
> 64-bit runs.
>      CUnit - A unit testing framework for C - Version 2.1-2
>      http://cunit.sourceforge.net/
> Suite: Shapefile Loader File shp2pgsql Test
>   Test: test_ShpLoaderCreate() ...passed
>   Test: test_ShpLoaderDestroy() ...Makefile:76: recipe for target 'check'
> failed
> make[2]: *** [check] Segmentation fault
> make[2]: Leaving directory '/projects/postgis/branches/2.4/loader/cunit'
> Makefile:157: recipe for target 'check' failed
> make[1]: *** [check] Error 2
> make[1]: Leaving directory '/projects/postgis/branches/2.4/loader'
> GNUmakefile:16: recipe for target 'check' failed
> make: *** [check] Error 1
> thought I ticketed this one before but guess not because it started
> happening suddenly one day on winnie's 32-bit runs so assume it was just
> a configuration problem.
> I should also add that winnie is the only but that runs these tests.  I
> had assumed the reason was that these were gui tests, but I see no
> reference to shp2pgsql-gui in these so not sure why the other bots
> shouldn't be running them as well.
New description:
 I thoughts this was just something wrong about the way I configured things
 on winnie's 32-bit runs, but now I have the same issue on my local 64-bit
 runs.
 failed
 happening suddenly one day on winnie's 32-bit runs so assume it was just a
 I should also add that winnie is the only bot that runs these tests.  I
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3839#comment:1>
