[postgis-tickets] [PostGIS] #3839: shp2pgsql cunit tests failing on Windows
PostGIS trac at osgeo.org
Sat Sep 9 19:13:32 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by robe):
 okay seemed to be crashing for me in the colmap_clean function.  Remarking
 that out made the error go away.  Though I can't figure out what I changed
 in my local to suddently start triggering the error.
 Anyway I'm seeing a bunch of questionable code in  shpcommon.c
 colmap_dbf_by_pg(colmap *map, const char *pgname)
   int i;
   for (i=0; i<map->size; ++i)
 shouldn't the counter be incremented after be i++ and not before?
 anyway it disagrees with the colmap_clean code which has the counter
 incrementing after as I would expect it to.
 colmap_clean(colmap *map)
         int i;
         if (map->size)
            for (i = 0; i < map->size; i++)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3839#comment:2>
