[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
PostGIS trac at osgeo.org
Sun Sep 17 12:48:46 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Interesting enough to me to setup a virtual Debian 9 32-bit to see how it
 behaves and I get the same failure on a normal build (no cassert / debug)
 so while this is now more than a fluke it should also be easier for me to
 hunt it down.
 Though, I also see failures for regress_brin_index regress_brin_index_3d
 which was unexpected. Any ideas?
 On this setup I got GEOS 3.5.1, PostgreSQL 9.6.4 and PROJ4 49.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:11>
