[postgis-tickets] [PostGIS] #3840: winnie 32-bit pg10 test failing on protobuf geobuf regress tests
PostGIS trac at osgeo.org
Sun Sep 17 16:45:48 PDT 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  assigned
  Priority:  high     |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 wow great you were able to reproduce it.  Don't feel quite so alone.
 hmm not seeing any issue with regress_brin_index or regress_brin_index_3d.
 How much memory do you have allocated for your VM?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3840#comment:12>
