[postgis-tickets] [PostGIS] #3851: Can't build postgis 2.1.9 docs
PostGIS trac at osgeo.org
Tue Sep 19 12:12:12 PDT 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.1.9
Component:  postgis  |    Version:  2.1.x
 Keywords:           |
 Seems there is an xml parse error in tags/2.1.9  and also in branch/2.1
 All the bots are also complaining and failing.
 The tar ball seems okay though so maybe the comments included in there
 were from a prior build.  I think it's only the comments building that
 would be botched by an xml parse error.
 So might only be an issue for folks trying to build from git or svn.
 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.1/extensions/postgis_topology'
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/2.1/extensions'
 PostGIS was built successfully. Ready to install.
 make -C doc check
 make[1]: Entering directory
 '/var/lib/jenkins/workspace/postgis/branches/2.1/doc'
 /usr/bin/xmllint --loaddtd --xinclude --valid postgis-out.xml > /dev/null
 release_notes.xml:11: element simplesect: validity error : Element
 simplesect content does not follow the DTD, expecting ((title , subtitle?
 , titleabbrev?) , (calloutlist | glosslist | bibliolist | itemizedlist |
 orderedlist | segmentedlist | simplelist | variablelist | caution |
 important | note | tip | warning | literallayout | programlisting |
 programlistingco | screen | screenco | screenshot | synopsis | cmdsynopsis
 | funcsynopsis | classsynopsis | fieldsynopsis | constructorsynopsis |
 destructorsynopsis | methodsynopsis | formalpara | para | simpara |
 address | blockquote | graphic | graphicco | mediaobject | mediaobjectco |
 informalequation | informalexample | informalfigure | informaltable |
 equation | example | figure | table | msgset | procedure | sidebar |
 qandaset | task | anchor | bridgehead | remark | highlights | abstract |
 authorblurb | epigraph | indexterm | beginpage)+), got ()
       </simplesect>
 Makefile:357: recipe for target 'check' failed
 make[1]: *** [check] Error 4
 GNUmakefile:88: recipe for target 'docs-check' failed
 make: *** [docs-check] Error 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3851>
