[postgis-tickets] [PostGIS] #3851: Can't build postgis 2.1.9 docs
PostGIS trac at osgeo.org
Tue Sep 19 21:30:32 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.1.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 okay looks like you fixed the xml error at r15773.  I fudged and used the
 release_notes.xml you patched to build the docs using rest of 2.1.9 tag.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3851#comment:1>
