[postgis-tickets] [PostGIS] #4031: ST_CurveToLine with small tolerance sometimes causes invalid memory alloc request size
PostGIS trac at osgeo.org
Tue Apr 24 05:54:40 PDT 2018
request size
  Reporter:  kkgeodk  |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  ST_CurveToLine
Comment (by strk):
 Ok I know what's happening here.
 The arc radius is 0.191861, so the sagitta (max distance between arc and
 cord) can be at most .383722. We're doing the computation using a distance
 of 1 instead (the tolerance) which results in 1-tolerance/radius to give
 an invalid input value for acos. This should be fixed by limiting the used
 value to always be at most the max possible error (arc diameter).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4031#comment:9>
