[postgis-tickets] [PostGIS] #4031: ST_CurveToLine with small tolerance sometimes causes invalid memory alloc request size
PostGIS trac at osgeo.org
Tue Apr 24 06:26:50 PDT 2018
request size
  Reporter:  kkgeodk  |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  ST_CurveToLine
Comment (by strk):
 In [changeset:"16553" 16553]:
 #!CommitTicketReference repository="" revision="16553"
 Survive to big max deviation values passed to ST_CurveToLine
 When using "max-deviation" tolerance type, passing a tolerance
 bigger than twice the radius of any arc resulted in entering
 an infinite loop, only limited by availability of RAM.
 This commit fixes the bug by being careful in what's fed to
 acos()...
 Includes a unit test.
 References #4031 for trunk (2.5.0dev) - to be backported
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4031#comment:10>
