[postgis-tickets] [PostGIS] #4099: upgrade script failing on winnie
PostGIS trac at osgeo.org
Sat Jun 2 19:49:35 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I forgot I had the job the version hardcoded so was still passing dev.  So
 fix was to change the job not the postgis code.
 I'll revisit later to make the ci script more resilient.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4099#comment:1>
