[postgis-tickets] [PostGIS] #4058: st_curvetoline hangs forever
PostGIS trac at osgeo.org
Sat Jun 2 19:53:08 PDT 2018
  Reporter:  mjurce   |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by robe):
 strk which version of geos/postgis are you using?
 Your reduced test case does not hang for me:
 POSTGIS="2.5.0alpha r16593" [EXTENSION] PGSQL="110" GEOS="3.7.0dev-
 CAPI-1.11.0 3fe3c03" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.4,
 released 2018/03/19" LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
 RASTER
 select st_npoints(ST_CurveToLine(
 'CIRCULARSTRING(2696000.55.831999999936670, 2695950.552000000141561
 1125749.833000000100583, 2695865.195999999996275  1125835.189000)'
 ::geometry, 0.0001, 1, 0))
 returns - 49551
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4058#comment:6>
