[postgis-tickets] [PostGIS] #4058: st_curvetoline hangs forever
PostGIS trac at osgeo.org
Sat Jun 2 20:05:18 PDT 2018
  Reporter:  mjurce   |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by robe):
 With the attached output2.txt (output.txt is fine) it does hang
 indefinitely, so I don't think your reduced test case is sufficient to
 replicate the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4058#comment:7>
