[postgis-tickets] [PostGIS] #3807: Change PostGIS library name to drop the minor
PostGIS trac at osgeo.org
Mon Oct 1 04:40:47 PDT 2018
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 3.0.0
 Component:  postgis   |    Version:  2.3.x
Resolution:  fixed     |   Keywords:
Comment (by Raul Marin):
 In [changeset:"16855" 16855]:
 #!CommitTicketReference repository="" revision="16855"
 Fix configure switch --with-library-minor-version in topology
 References #3807
 Closes https://github.com/postgis/postgis/pull/312
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3807#comment:7>
