[postgis-tickets] r16856 - St_AsMVTGeom: Fix bug when clipping an invalid geometry
Raul
raul at rmr.ninja
Mon Oct 1 05:59:05 PDT 2018
Author: algunenano
Date: 2018-10-01 05:59:05 -0700 (Mon, 01 Oct 2018)
New Revision: 16856
trunk/NEWS
trunk/postgis/mvt.c
trunk/regress/mvt.sql
trunk/regress/mvt_expected
If the geometry becomes invalid after simplifying, the clipping
could be invalid too. For those cases we drop the geometry.
Modified: trunk/NEWS
--- trunk/NEWS 2018-10-01 11:40:46 UTC (rev 16855)
+++ trunk/NEWS 2018-10-01 12:59:05 UTC (rev 16856)
@@ -19,6 +19,7 @@
- #4161, MVT: Drop geometries smaller than the resolution (Raúl Marín)
- #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
- #4181, St_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
+ - #4183, St_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
PostGIS 2.5.0
2018/09/23
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2018-10-01 11:40:46 UTC (rev 16855)
+++ trunk/postgis/mvt.c 2018-10-01 12:59:05 UTC (rev 16856)
@@ -894,10 +894,30 @@
double y0 = bgbox.ymin;
double x1 = bgbox.xmax;
double y1 = bgbox.ymax;
- lwgeom = lwgeom_clip_by_rect(lwgeom, x0, y0, x1, y1);
- POSTGIS_DEBUG(3, "mvt_geom: no geometry after clip");
- if (lwgeom == NULL || lwgeom_is_empty(lwgeom))
+ const GBOX pre_clip_box = *lwgeom_get_bbox(lwgeom);
+ LWGEOM *clipped_geom = lwgeom_clip_by_rect(lwgeom, x0, y0, x1, y1);
+ if (clipped_geom == NULL || lwgeom_is_empty(clipped_geom))
+ POSTGIS_DEBUG(3, "mvt_geom: no geometry after clip");
return NULL;
+ /* For some polygons, the simplify step might have left them
+ * as invalid, which can cause clipping to return the complementary
+ * geometry of what it should */
+ if ((lwgeom->type == POLYGONTYPE ||
+ lwgeom->type == MULTIPOLYGONTYPE ||
+ lwgeom->type == COLLECTIONTYPE) &&
+ !gbox_contains_2d(&pre_clip_box, lwgeom_get_bbox(clipped_geom)))
+ /* TODO: Adapt this when and if Exception Policies are introduced.
+ * Other options would be to fix the geometry and retry
+ * or to calculate the difference between the 2 boxes.
+ POSTGIS_DEBUG(3, "mvt_geom: Invalid geometry after clipping");
+ lwgeom_free(clipped_geom);
+ return NULL;
+ lwgeom = clipped_geom;
Modified: trunk/regress/mvt.sql
--- trunk/regress/mvt.sql 2018-10-01 11:40:46 UTC (rev 16855)
+++ trunk/regress/mvt.sql 2018-10-01 12:59:05 UTC (rev 16856)
@@ -265,6 +265,14 @@
16,
true));
+-- Invalid geometry after simplification with invalid clipping
+SELECT 'PG45', ST_AsEWKT(ST_AsMVTGeom(
+ 'SRID=3857;MULTIPOLYGON(((-8231365.02893734 4980355.83678553,-8231394.82332406 4980186.31880185,-8231367.43081065 4979982.17443372,-8231396.69199339 4980227.59327083,-8231365.02893734 4980355.83678553)))'::geometry,
+ 'SRID=3857;POLYGON((-8238115.3789773 4970203.10870116,-8238115.3789773 4980063.48534995,-8228255.00232851 4980063.48534995,-8228255.00232851 4970203.10870116,-8238115.3789773 4970203.10870116))'::geometry,
+ 4096,
+ 16,
+ true));
-- geometry encoding tests
SELECT 'TG1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM (SELECT 1 AS c1,
ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
Modified: trunk/regress/mvt_expected
--- trunk/regress/mvt_expected 2018-10-01 11:40:46 UTC (rev 16855)
+++ trunk/regress/mvt_expected 2018-10-01 12:59:05 UTC (rev 16856)
@@ -47,6 +47,7 @@
PG43 - ON |MULTIPOLYGON(((5 5,0 0,10 0,5 5)),((0 10,5 5,10 10,0 10)))
PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
PG44|
+PG45|
TG1|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
TG2|GiMKBHRlc3QSDhICAAAYASIGETLePwIBGgJjMSICKAEogCB4Ag==
TG3|GiYKBHRlc3QSERICAAAYAiIJCQCAQArQD88PGgJjMSICKAEogCB4Ag==
