[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
PostGIS trac at osgeo.org
Sun Oct 14 00:58:30 PDT 2018
  Reporter:  strk                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 2.1.1
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  extension
Comment (by strk):
 Another easier way in which you can reproduce:
 regress/run_test.pl -v --topology --extension \
   --upgrade-path unpackaged--3.0.0dev \
   topology/test/regress/gml.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:20>
