[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
PostGIS trac at osgeo.org
Mon Oct 15 20:44:49 PDT 2018
  Reporter:  strk                   |      Owner:  robe
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 2.1.1
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  extension
Comment (by strk):
 Testing of upgrades was committed and revealed this issue does not affect
 upgrades from previous topology releases. But it does affect upgrades from
 unpackaged (on my machine) which is still untested. Having bots check
 upgrades from unpackaged is hanlded in #4204 (although I'm thinking we
 should check that from the normal "make installcheck" rather than reaching
 out to utils/check_all_upgrades.sh in that upgrades from unpackage don't
 need any previous version installed on the system)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:21>
