[postgis-tickets] [PostGIS] #4210: PostGIS 3.0 is completely broken
PostGIS trac at osgeo.org
Sat Oct 20 08:49:57 PDT 2018
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 For reference this is what debbie is showing:
 /usr/bin/perl -pi.bak -e
 's,\$libdir,/var/lib/jenkins/workspace/postgis/branches/3.0/regress/00
 -regress-install/lib,g'
 /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/*.sql
 #make -C ../loader REGRESS=1
 DESTDIR=/var/lib/jenkins/workspace/postgis/branches/3.0/regress/00
 -regress-install install
 make -C core check
 make[2]: Entering directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress/core'
 /usr/bin/perl ../run_test.pl  ../loader/Point ../loader/PointM
 ../loader/PointZ ../loader/MultiPoint ../loader/MultiPointM
 ../loader/MultiPointZ ../loader/Arc ../loader/ArcM ../loader/ArcZ
 ../loader/Polygon ../loader/PolygonM ../loader/PolygonZ
 ../loader/TSTPolygon ../loader/TSIPolygon ../loader/TSTIPolygon
 ../loader/PointWithSchema ../loader/NoTransPoint
 ../loader/NotReallyMultiPoint ../loader/MultiToSinglePoint
 ../loader/ReprojectPts ../loader/ReprojectPtsGeog ../loader/Latin1
 ../loader/Latin1-implicit ../loader/mfile dumper/literalsrid
 dumper/realtable affine bestsrid binary boundary chaikin filterm cluster
 concave_hull concave_hull_hard ctors curvetoline dump dumppoints empty
 estimatedextent forcecurve geography geometric_median in_geohash in_gml
 in_kml in_encodedpolyline iscollection legacy long_xact lwgeom_regress
 measures minimum_bounding_circle normalize operators orientation
 out_geometry out_geography polygonize polyhedralsurface postgis_type_name
 quantize_coordinates regress regress_bdpoly regress_index
 regress_index_nulls regress_management regress_selectivity regress_lrs
 regress_ogc regress_ogc_cover regress_ogc_prep regress_proj relate
 remove_repeated_points removepoint reverse setpoint simplify simplifyvw
 size snaptogrid split sql-mm-serialize sql-mm-circularstring sql-mm-
 compoundcurve sql-mm-curvepoly sql-mm-general sql-mm-multicurve sql-mm-
 multisurface swapordinates summary temporal tickets twkb typmod wkb wkt
 wmsservers knn_recheck temporal_knn hausdorff regress_buffer_params
 frechet offsetcurve relatematch isvaliddetail sharedpaths snap node
 unaryunion clean relate_bnr delaunaytriangles clipbybox2d subdivide
 voronoi minimum_clearance oriented_envelope in_geojson regress_brin_index
 regress_brin_index_3d regress_brin_index_geography mvt geobuf mvt_jsonb
 Unable to find
 /var/lib/jenkins/workspace/postgis/branches/3.0/regress/../loader/shp2pgsql
 executable.
 PATH is
 /var/lib/jenkins/workspace/pg/rel/pg10w64/bin:/var/lib/jenkins/workspace/pg/rel/pg10w64/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
 Checking for shp2pgsql ... failed
 make[2]: *** [Makefile:257: check] Error 2
 make[2]: Leaving directory
 make[1]: *** [Makefile:29: check-core] Error 2
 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.0/regress'
 make: *** [GNUmakefile:20: all] Error 1
 Build step 'Execute shell' marked build as failure
 Dronie:
 `/drone/src/git.osgeo.org/gogs/postgis/postgis/regress/core'
 offsetcurve relatematch isvaliddetail sharedpaths snap node unaryunion
 clean relate_bnr delaunaytriangles clipbybox2d subdivide voronoi
 Unable to find
 /drone/src/git.osgeo.org/gogs/postgis/postgis/regress/../loader/shp2pgsql
 executable.
 PATH is
 /usr/lib/postgresql/10/bin:/usr/lib/postgresql/10/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
 make[2]: *** [check] Error 2
 make[1]: *** [check-core] Error 2
 `/drone/src/git.osgeo.org/gogs/postgis/postgis/regress'
 make: *** [all] Error 1
 Travis:
 cc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
 -fno-strict-aliasing -fwrapv -fexcess-precision=standard -O2 -fPIC -shared
 -o rtpostgis-3.so rtpostgis.o rtpg_internal.o rtpg_spatial_relationship.o
 rtpg_mapalgebra.o rtpg_utility.o rtpg_inout.o rtpg_wkb.o rtpg_geometry.o
 rtpg_raster_properties.o rtpg_band_properties.o rtpg_pixel.o rtpg_create.o
 rtpg_gdal.o rtpg_statistics.o -L/usr/local/pgsql/lib    -Wl,--as-needed
 -Wl,-rpath,'/usr/local/pgsql/lib',--enable-new-dtags
 ../rt_core/librtcore.a ../../liblwgeom/.libs/liblwgeom.a
 ../../libpgcommon/libpgcommon.a -L/usr/local/lib -lgdal  -L/usr/local/lib
 -lgeos_c -lproj  -ljson-c -lprotobuf-c -lxml2 -L/usr/local/lib -lSFCGAL
 -Wl,--exclude-libs,ALL -Wl,-Bsymbolic-functions -Wl,-z,relro
 /usr/bin/install -c -m 755  rtpostgis-3.so '/src/postgis/regress/00
 -regress-install/lib/rtpostgis-3.so'
 /usr/bin/install -c -m 644  rtpostgis.sql rtpostgis_for_extension.sql
 rtpostgis_upgrade_for_extension.sql rtpostgis_upgrade.sql
 rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql
 rtpostgis_legacy.sql '/src/postgis/regress/00-regress-
 install/share/contrib/postgis/'
 make[2]: Leaving directory '/src/postgis/raster/rt_pg'
 make[1]: Leaving directory '/src/postgis/regress'
 GNUmakefile:20: recipe for target 'all' failed
 [logbt] saw 'make' exit with code:2 (INT)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4210#comment:2>
