[postgis-tickets] [PostGIS] #4210: PostGIS 3.0 is completely broken
PostGIS trac at osgeo.org
Sun Oct 21 00:24:51 PDT 2018
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Sorry, should be fixed with r16930 (I inadvertently left the default make
 target under regress/ to be "check" instead of a do-nothing rule)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4210#comment:3>
