[postgis-tickets] r16958 - Use TupleDescAttr instead of its internal representation
Raul raul at rmr.ninja
Mon Oct 29 06:52:42 PDT 2018
Author: algunenano
Date: 2018-10-29 06:52:42 -0700 (Mon, 29 Oct 2018)
New Revision: 16958
   trunk/libpgcommon/pgsql_compat.h
   trunk/postgis/geobuf.c
   trunk/postgis/mvt.c
   trunk/topology/postgis_topology.c
Closes https://trac.osgeo.org/postgis/ticket/4213
Closes https://github.com/postgis/postgis/pull/322
Modified: trunk/libpgcommon/pgsql_compat.h
--- trunk/libpgcommon/pgsql_compat.h	2018-10-29 04:10:46 UTC (rev 16957)
+++ trunk/libpgcommon/pgsql_compat.h	2018-10-29 13:52:42 UTC (rev 16958)
@@ -1,9 +1,11 @@
 #ifndef _PGSQL_COMPAT_H
 #define _PGSQL_COMPAT_H 1
-/* Make sure PG_NARGS is defined for older PostgreSQL versions */
-#ifndef PG_NARGS
-#define PG_NARGS() (fcinfo->nargs)
+#include "access/tupdesc.h"
+/* TupleDescAttr was backported into 9.6.5 but we support any 9.6.X */
+#ifndef TupleDescAttr
+#define TupleDescAttr(tupdesc, i) ((tupdesc)->attrs[(i)])
 #endif
 #endif /* _PGSQL_COMPAT_H */
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c	2018-10-29 04:10:46 UTC (rev 16957)
+++ trunk/postgis/geobuf.c	2018-10-29 13:52:42 UTC (rev 16958)
@@ -24,6 +24,7 @@
 #include <math.h>
 #include "geobuf.h"
+#include "pgsql_compat.h"
 #ifdef HAVE_LIBPROTOBUF
@@ -57,13 +58,8 @@
 	uint32_t i, k = 0;
 	bool geom_found = false;
 	for (i = 0; i < natts; i++) {
-#if POSTGIS_PGSQL_VERSION < 110
-		Oid typoid = getBaseType(tupdesc->attrs[i]->atttypid);
-		char *tkey = tupdesc->attrs[i]->attname.data;
-#else
-		Oid typoid = getBaseType(tupdesc->attrs[i].atttypid);
-		char *tkey = tupdesc->attrs[i].attname.data;
-#endif
+		Oid typoid = getBaseType(TupleDescAttr(tupdesc, i)->atttypid);
+		char *tkey = TupleDescAttr(tupdesc, i)->attname.data;
 		char *key = pstrdup(tkey);
 		if (ctx->geom_name == NULL) {
 			if (!geom_found && typoid == TypenameGetTypid("geometry")) {
@@ -127,11 +123,9 @@
 		datum = GetAttributeByNum(ctx->row, i + 1, &isnull);
 		if (isnull)
 			continue;
-		typoid = getBaseType(tupdesc->attrs[i]->atttypid);
-#else
-		typoid = getBaseType(tupdesc->attrs[i].atttypid);
-#endif
+		typoid = getBaseType(TupleDescAttr(tupdesc, i)->atttypid);
 		if (strcmp(type, "int2") == 0) {
 			set_int_value(value, DatumGetInt16(datum));
 		} else if (strcmp(type, "int4") == 0) {
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2018-10-29 04:10:46 UTC (rev 16957)
+++ trunk/postgis/mvt.c	2018-10-29 13:52:42 UTC (rev 16958)
@@ -25,6 +25,7 @@
 #include <string.h>
 #include "mvt.h"
@@ -334,13 +335,8 @@
-		Oid typoid = getBaseType(ctx->column_cache.tupdesc->attrs[i]->atttypid);
-		char *tkey = ctx->column_cache.tupdesc->attrs[i]->attname.data;
-#else
-		Oid typoid = getBaseType(ctx->column_cache.tupdesc->attrs[i].atttypid);
-		char *tkey = ctx->column_cache.tupdesc->attrs[i].attname.data;
-#endif
+		Oid typoid = getBaseType(TupleDescAttr(ctx->column_cache.tupdesc, i)->atttypid);
+		char *tkey = TupleDescAttr(ctx->column_cache.tupdesc, i)->attname.data;
 		ctx->column_cache.column_oid[i] = typoid;
 #if POSTGIS_PGSQL_VERSION >= 94
@@ -726,11 +722,7 @@
 			continue;
-		key = cc.tupdesc->attrs[i]->attname.data;
-#else
-		key = cc.tupdesc->attrs[i].attname.data;
-#endif
+		key = TupleDescAttr(cc.tupdesc, i)->attname.data;
 		k = cc.column_keys_index[i];
 		typoid = cc.column_oid[i];
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c	2018-10-29 04:10:46 UTC (rev 16957)
+++ trunk/topology/postgis_topology.c	2018-10-29 13:52:42 UTC (rev 16958)
@@ -32,6 +32,7 @@
 /*#define POSTGIS_DEBUG_LEVEL 1*/
 #include "lwgeom_log.h"
 #include "lwgeom_pg.h"
 #include <stdarg.h>
@@ -257,11 +258,7 @@
   /* we're dynamically querying geometry type here */
-  topo->geometryOID = SPI_tuptable->tupdesc->attrs[3]->atttypid;
-#else
-  topo->geometryOID = SPI_tuptable->tupdesc->attrs[3].atttypid;
-#endif
+  topo->geometryOID = TupleDescAttr(SPI_tuptable->tupdesc, 3)->atttypid;
   POSTGIS_DEBUGF(1, "cb_loadTopologyByName: topo '%s' has "
                  "id %d, srid %d, precision %g",
