[postgis-tickets] r16960 - More style tweaks and add 'chucked-html-web' target for
Paul Ramsey pramsey at cleverelephant.ca
Mon Oct 29 03:20:48 PDT 2018
Author: pramsey
Date: 2018-10-29 15:20:48 -0700 (Mon, 29 Oct 2018)
New Revision: 16960
Added:
   trunk/doc/html/ga.js
   trunk/doc/Makefile.in
   trunk/doc/html/style.css
building ref docs with google analytics code embedded
Modified: trunk/doc/Makefile.in
--- trunk/doc/Makefile.in	2018-10-29 20:22:41 UTC (rev 16959)
+++ trunk/doc/Makefile.in	2018-10-29 22:20:48 UTC (rev 16960)
@@ -62,10 +62,15 @@
 	--param simplesect.in.toc 0 \
 	--param use.id.as.filename 1 \
 	--param chunk.quietly 1 \
+	--param header.rule 0 \
+	--param footer.rule 0 \
+	--param table.borders.with.css 1 \
+	--stringparam chunker.output.encoding UTF-8 \
+	--stringparam chunker.output.indent no \
+	--stringparam saxon.character.representation decimal \
+	--stringparam html.stylesheet style.css \
 	$(XSLTPROCFLAGS)
-XSLTPROC_HTMLOPTS= \
-	--stringparam html.stylesheet style.css \
 HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
 CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
@@ -138,7 +143,7 @@
 	reporting.xml \
 	using_postgis_app.xml \
 	using_postgis_dataman.xml \
-	using_raster_dataman.xml
+	using_raster_dataman.xml
 XML_GENERATED_SOURCES = \
 	postgis_aggs_mm.xml \
@@ -209,31 +214,31 @@
 postgis_comments.sql: ./xsl/postgis_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/postgis_comments.sql.xsl postgis-out.xml > $@
 postgis_cheatsheet.html: ./xsl/postgis_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/postgis_cheatsheet.html.xsl postgis-out.xml > $@
 raster_comments.sql: ./xsl/raster_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/raster_comments.sql.xsl postgis-out.xml > $@
 raster_cheatsheet.html: ./xsl/raster_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/raster_cheatsheet.html.xsl postgis-out.xml > $@
 topology_comments.sql: ./xsl/topology_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/topology_comments.sql.xsl postgis-out.xml > $@
 topology_cheatsheet.html: ./xsl/topology_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/topology_cheatsheet.html.xsl postgis-out.xml > $@
 sfcgal_comments.sql: ./xsl/sfcgal_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/sfcgal_comments.sql.xsl postgis-out.xml > $@
 sfcgal_cheatsheet.html: ./xsl/sfcgal_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/sfcgal_cheatsheet.html.xsl postgis-out.xml > $@
 tiger_geocoder_comments.sql: ./xsl/tiger_geocoder_comments.sql.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/tiger_geocoder_comments.sql.xsl postgis-out.xml > $@
 tiger_geocoder_cheatsheet.html: ./xsl/tiger_geocoder_cheatsheet.html.xsl $(XML_INPUTS)
 	$(XSLTPROC) --novalid ./xsl/tiger_geocoder_cheatsheet.html.xsl postgis-out.xml > $@
@@ -241,12 +246,19 @@
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@
 chunked-html: postgis-out.xml Makefile images $(XML_INPUTS)
-	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) $(XSLTPROC_HTMLOPTS) \
+	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
 		--output html/ \
-		--stringparam saxon.character.representation decimal \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
+chunked-html-web: postgis-out.xml Makefile images $(XML_INPUTS)
+		--output html/ \
+		--stringparam html.script ga.js \
+		$(CHUNK_HTML_DOCBOOK_XSL) \
 html: html/postgis$(DOCSUFFIX).html
 html-localized:
@@ -256,7 +268,7 @@
   done
 html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile images $(XML_INPUTS)
 		--output html/postgis$(DOCSUFFIX).html \
 		$(HTML_DOCBOOK_XSL) \
@@ -280,7 +292,7 @@
 		   -s "${PWD}/texstyle.sty" \
 		   -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf $<; \
 	fi
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub: postgis-out.xml images $(XML_INPUTS)
 	if test x"$(DBTOEPUB)" = x; then \
 	   echo "Error: dbtoepub not found, can't build epub"; \
@@ -308,13 +320,13 @@
 doxygen: doxygen.cfg
 	doxygen $<
-images:
+images:
 	$(MAKE) -C html/image_src images
 images-clean:
 	$(MAKE) -C html/image_src images-clean
-clean:
+clean:
 	rm -f html/*.html
 	rm -f postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.pdf
 	rm -f *.epub
@@ -339,7 +351,7 @@
 cheatsheets: postgis_cheatsheet.html raster_cheatsheet.html topology_cheatsheet.html sfcgal_cheatsheet.html tiger_geocoder_cheatsheet.html
 ifneq ($(CAN_BUILD_COMMENTS),yes)
-comments-install:
+comments-install:
 	if test -e postgis_comments.sql  -a \
 	        -e raster_comments.sql   -a \
 	        -e topology_comments.sql -a \
@@ -371,7 +383,7 @@
 	$(INSTALL_DATA) html/images/* $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images/
 	$(INSTALL_DATA) ../README.postgis $(DESTDIR)$(PGSQL_DOCDIR)/postgis/README.postgis
-docs-uninstall:
+docs-uninstall:
 	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/postgis.html
 	rm -f $(DESTDIR)$(PGSQL_DOCDIR)/postgis/style.css
 	rm -rf $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images
@@ -437,11 +449,11 @@
 	@echo
 requirements_not_met_imagemagick:
-	@echo
+	@echo
 	@echo "configure was unable to find the ImageMagick's 'convert' utility program."
 	@echo "To build the documentation, install ImageMagick and then re-run configure. Alternatively "
 	@echo "refer to online manual:"
 	@echo
 	@echo "  http://postgis.net/documentation"
-	@echo
+	@echo
Added: trunk/doc/html/ga.js
--- trunk/doc/html/ga.js	                        (rev 0)
+++ trunk/doc/html/ga.js	2018-10-29 22:20:48 UTC (rev 16960)
@@ -0,0 +1,7 @@
+(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){
+(i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),
+m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
+})(window,document,'script','https://www.google-analytics.com/analytics.js','ga');
+ga('create', 'UA-37775762-1', 'auto');
+ga('send', 'pageview');
Modified: trunk/doc/html/style.css
--- trunk/doc/html/style.css	2018-10-29 20:22:41 UTC (rev 16959)
+++ trunk/doc/html/style.css	2018-10-29 22:20:48 UTC (rev 16960)
@@ -10,16 +10,16 @@
     background: #ffffff;
     color: #2e2e2e;
     margin: 0;
-    padding: 0em 4em 0em 4em;
+    padding: 0em 6em 0em 6em;
 div.navheader {
-    margin: 0em -4em 0em -4em;
-    padding: 2em;
+    margin: 0em -6em 0em -6em;
+    padding: 2em 6em 2em 6em;
     background: #579;
 div.navfooter {
     background: #579;
     color: white;
@@ -51,13 +51,6 @@
     display: none;
-div.refentry {
-    margin: 2em;
-hr {
-     display: none;
 div.funcsynopsis code {
     font: unset;
@@ -70,13 +63,13 @@
 a:hover, li a:hover, h2 a:hover, h3 a:hover, h4 a:hover, h5 a:hover {
     color: #e9cb2b;
-p,form,td,th,dt,li{
+p, form, td, th, dt, li {
 /*   font-size:10pt */
 h1, h2 {
     color: #579;
-h3,h4,th,dt,b, div.abstract-title, div.toc-title {
+h3, h4, th, dt, b, div.abstract-title, div.toc-title {
     color: #579;
 h1 {
@@ -108,10 +101,6 @@
     border-collapse: collapse;
-/*table, td {
-    border: 1;
-    padding: 0
 /* 3. Block Formatted ----------------------------------------------------- */
@@ -166,7 +155,6 @@
     margin: 0 0 0 0;
     padding: 0 0 0 0;
 div.warning table tr td img {
     margin: 0 0.5em 0 0;
     padding: 0 0 0 0;
@@ -194,8 +182,6 @@
     padding: 0 0 0 0;
 span.inlinemediaobject img {
     vertical-align: middle;
@@ -257,17 +243,8 @@
     font-weight: bold;
-.styledtable table thead th {
-    border-color: #ddd;
-    border-style: solid;
-.styledtable > table {
 .styledtable table td,th {
-     color: black;
-     padding: 0.3em;
+    padding: 0.5em;
 table.informaltable {
