[postgis-tickets] [PostGIS] #4166: make install is broken
PostGIS trac at osgeo.org
Sun Sep 2 11:49:05 PDT 2018
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Make install is broken.  Seeing this on all the bots
 Seems to be an issue since I flipped the switch, which is odd, cause I
 didn't even change to dropping the minor
 +\cd: could not change directory to
 "E:/jenkins/postgresql/rel/pg10w64gcc48/share/contrib/postgis-3.": No such
 file or directory
 +psql:legacy.sql:11: \cd: could not change directory to
 file or directory
 file or directory
 So perhaps something else in our code is causing it
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4166>
