[postgis-tickets] [PostGIS] #4166: make install is broken
PostGIS trac at osgeo.org
Sun Sep 2 11:49:56 PDT 2018
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> Make install is broken.  Seeing this on all the bots
> Seems to be an issue since I flipped the switch, which is odd, cause I
> didn't even change to dropping the minor
> +\cd: could not change directory to
> "E:/jenkins/postgresql/rel/pg10w64gcc48/share/contrib/postgis-3.": No
> such file or directory
> +psql:legacy.sql:11: \cd: could not change directory to
> So perhaps something else in our code is causing it
New description:
  legacy .. failed (diff expected obtained:
 /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0dev_gdal2.2.4w64/test_50_diff)
 --- legacy_expected     2017-10-26 19:18:11.560448900 -0400
 /projects/postgis/tmp/3.0.0dev_pg10_geos3.7.0dev_gdal2.2.4w64/test_50_out
 2018-08-29 12:42:35.641212200 -0400
 @@ -1,21 +1,9691 @@
 "E:/jenkins/postgresql/rel/pg10w64gcc48/share/contrib/postgis-3.": No such
 file or directory
 file or directory
 file or directory
 file or directory
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4166#comment:1>
