[postgis-tickets] [PostGIS] #4166: make install is broken
PostGIS trac at osgeo.org
Sun Sep 2 11:54:52 PDT 2018
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by robe):
 shows a little differently on bessie but still failing at the legacy bit
 06:05:33  legacy ..FATAL: command execution failed
 06:57:22 java.io.EOFException
 06:57:22        at
 java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2681)
 06:57:22        at
 java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:3156)
 06:57:22        at
 java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:862)
 06:57:22        at
 java.io.ObjectInputStream.<init>(ObjectInputStream.java:358)
 06:57:22        at
 hudson.remoting.ObjectInputStreamEx.<init>(ObjectInputStreamEx.java:48)
 06:57:22        at hudson.remoting.Command.readFrom(Command.java:140)
 06:57:22        at hudson.remoting.Command.readFrom(Command.java:126)
 06:57:22        at
 hudson.remoting.AbstractSynchronousByteArrayCommandTransport.read(AbstractSynchronousByteArrayCommandTranspo
 Debbie showing failure on legacy, so perhaps it's just the regex in legacy
 is screwed
 legacy .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_50_diff)
 --- legacy_expected     2018-08-19 22:53:18.856431279 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_50_out
 2018-08-28 07:17:03.594381508 +0000
 @@ -1,21 +1,5446 @@
 -Starting up MapServer/Geoserver tests...
 -Setting up the data table...
 -public.wmstest.pt SRID:4326 TYPE:POLYGON DIMS:2
 -Running Geoserver 2.0 NG tests...
 -Geoserver1|POLYGON
 -Geoserver2|4326
 -Geoserver3|-500|AAAAAAMAAAABAAA
 -Geoserver4|1
 -Geoserver5|25|AAAAAAMAAAABAAA
 -Geoserver6|25|AAAAAAMAAAABAAA
 -MapServer1|id
 -MapServer2|-9465|AQcAAAABAAAAAQM|-9465
 -MapServer2|-9460|AQcAAAABAAAAAQM|-9460
 -MapServer3|id
 -MapServer4|-9465|010700000001000|-9465
 -MapServer4|-9460|010700000001000|-9460
 -Removing the data table...
 -Done.
 -1869|POINT(1 2)
 -BEGIN
 -COMMIT
 +\cd: could not change directory to
 "/var/lib/jenkins/workspace/pg/rel/pg10w64/share/postgresql/contrib/postgis-3.":
 No such file or directory
 +psql:legacy.sql:11: \cd: could not change directory to
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4166#comment:2>
