[postgis-tickets] [PostGIS] #4173: Undefined behaviour in ptarray_segmentize2d
trac at osgeo.org
Fri Sep 7 03:11:21 PDT 2018
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
It comes from test `test_lwgeom_segmentize2d`:
linein = lwgeom_from_wkt("LINESTRING(0 0,10 0)",
LW_PARSER_CHECK_NONE);
lwgeom_request_interrupt();
lineout = lwgeom_segmentize2d(linein, 1e-100);
CU_ASSERT_EQUAL(lineout, NULL);
lwgeom_free(linein);
$ ./cunit/.libs/lt-cu_tester test_lwgeom_segmentize2d
Running test 'test_lwgeom_segmentize2d' in suite 'measures'.
ptarray.c:450:10: runtime error: 1e+101 is outside the range of
representable values of type 'unsigned int'
I'll need to check if it affects both 3.0 and 2.5.
I feel that the code is probably filled with these kind of issues (unsafe
casting from double to integer types), but since those are corner cases
I'll limit myself to fix whatever comes up when running unit tests.
WIP in https://github.com/postgis/postgis/pull/292
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4173>
