[postgis-tickets] [PostGIS] #4172: Memory leak in lwgeom_offsetcurve
PostGIS trac at osgeo.org
Fri Sep 7 03:59:01 PDT 2018
  Reporter:  Algunenano  |      Owner:  Algunenano
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 2.5.0
 Component:  postgis     |    Version:  2.4.x
Resolution:  fixed       |   Keywords:
Changes (by Raul Marin):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16722" 16722]:
 #!CommitTicketReference repository="" revision="16722"
 Fix memory leak in lwgeom_offsetcurve
 Closes #4172
 Closes https://github.com/postgis/postgis/pull/291
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4172#comment:2>
